frosh29
- 293
- 31
- Jul 29, 2004
Wallington,
New_Jersey
This all started when I replaced my two rear brake lines. I also opened the wrong brake flairs at the proportion valve (now closed obv). ive replaced the master brake cylinder, no fluid leaking anywhere, but when I press the brakes the pedal is soft unless I press the brake pedal twice in quick succession. I’ve also bled the brakes 3 times with the car Off and on.
Still get mushy pedal if I don’t hit the pedal twice.
Abs light is on. It’s a 95 so I can’t read the codes without a mut from what I’ve read.
Any wisdom someone can impart?
Thanks!
Thanks!
