Any Dsms' In San Antonio ?
Right on! Im not too far from were you stay. And hey if its not one thing its another. So you mean your mechanical timing is off, not the ignition timing?
Also, I have a basic little boost leak tester we can use if you dont already have one. We'd need a good size air compressor though.
Yeah mechanical I had to replace the water pump . And oh nice I was gonna make one and I read you could use a bike pump. I don't have an air compressor I need to buy one tho . I'll be home Monday morning and be working on the car all week. Just hit me up if you wanna check things out. I'm just trying to get it running. And then I'll start buying all the parts to upgrade.
Yeah there easy to make but if u want i could still bring mine over some time. do you know the coupler size on the turbo compressor inlet?
And yes a small compressor or hand pump could possibly work. But a good size one that could feed a larger amount of air faster in the IM would be more effective. Im working monday mornings usually but my schedule changes offten.
Yeah it should he the factory size I'm guessing 2 inch, Maybe 2.5. Oh nice I usually only work on it Monday thru Friday since gf and kids are gone. And the weekends is for resting and with the family.
Did you get er' timed?
Also I have a coupler that'll fit the stock T25 and the boost leak tester. Let me know, if you want I can drop it off to you or stay an help but during the week im only free after 4pm
