rj uhrina
- 1
- Jul 26, 2019
waunakee,
Wisconsin
I’ve been doing a lot of research. So I believe if I have this right, the stock turbo is an internal actuator setup. So that being said how would I be able to run more boost, because from what I’ve read you can only reach around 12 psi. I have a HKS SQV 4 BOV, and a turbo smart manual boost controller sitting around and I don’t know if that would increase the amount of boost the stock turbo can run since it is an internal actuator setup. I know there are ways to weld the internal gate passage shut, and delete the actuator setup entirely so I can run an external waste gate but is there a way around this? Any feedback is helpful, my main goal is to be running more boost.
