jongreene
- 484
- 6
- Nov 3, 2005
midland,
Michigan
So this car has the little fuse block, between B+ and the fuse block. There were two 30A fuses. The 30A fuse that is in the circuit with the 100A alternator fuse has been popping after a new alternator was installed. I was under the impression that the little fuse block is unnecessary and I could delete that, replace the 4 white wires and have a straight shot to the battery, am I correct?
Also, the small gauge wire that goes to 20A cond.fan/vent.cond...replace that wire, re-splice it into the new wires or safe to delete that?
