Tuomas
- 5
- Jun 5, 2019
Norrköping,
Europe
I need som insperation so post some pictures of your setup!
If you are concerned about wheel gap- how far wheels stick outside of wheel well- 8.5" with a +35mm offset puts the rubber about a 0.25" (that is the setup I have)
It isn't flush if that is what you are going for, but I needed to clear my big boy brakes and I did so with about 2 mm to spare
Mine 19x8 40ET 235-35/19
Thanks for the input! Yesterday we tried a 8x19" rim with ET35 and it did poke outside the fender maybe 5-10mm. Hard to measure without any rubber on the rim. but we measured the clerance to the controlarm from the rim and there was maybe 20mm clearence. (without rubber). So I am now thinkin on ET40 with a 7.5" rim. That would set the tire just in line with the fender and get more space between the control bar and wheel. I have to take in to account that I have to lower the car aswell. Thing is 7.5x19 is hard do get
