Turbo exhaust housing - good or no good
tsiawd90
Supporting Member
101
22
Nov 16, 2017
Houston, Texas
I was moving my stock turbo and housing to my new motor and this is how the exhaust housing looks
Is this ok or do I need to find another.
Also is it possible to swap this myself or is there anything more involved than dissembling and reassembling the new one. IS there any alignment or anything else to be concerned with when doing the swap?
And last where can I buy just the exhaust housing?
The hot side is held to your turbo with a large clamp that clamps the turbo and the hot side together. Other than the bolts for the exhaust, you should be able to pop yours out and into another, good unit.
ok I ordered the one in the link. Will I need any addition items to get this installed?
Turbo to exhaust housing gasket and exhaust housing to manifold gasket....and a 6 pack!:thumb:
Inspect the bolt holes when it comes. A couple of us had bad luck with the Ebay turbine housings. I would have suggested turrbolab instead of Ebay, but if the bolt holes are correct you should have no issues.
Edit. This housing uses a cotter pin on the wg. I cant remember if the stock one uses a c clamp or cotter pin.
It’s from turbo lab. Pic is from the description from the link I posted above. I do however understand about eBay (well Chinabay) parts not fitting correct due to casting errors.
