EC17PSE
Freelancer
- 5,889
- 3,478
- Nov 1, 2008
London, UK,
Europe
Hey everyone, IM back again with these and will be offering them up on a pre order.
I'm going to run these off at the same time as the OEM Front and Rear OEM Billet ARB brackets so should hopefully be ready to start shipping by late sept/oct time 2022.
If you wish to get a set of OEM front brackets also here is where you can find them https://www.dsmtuners.com/threads/closed-new-item-2g-oem-billet-anti-roll-bar-brackets.529431/
The reason I made these is the lack of bars available for the DSM! And everyone complains about the bars we have and don't have! So this opens up a whole different batch of parts and bigger/adjustable bars!
While i have explored blades and hollow bars the setup is not exactly simple and certainly not cheap! At all!!! So I have looked at every angle for you all while keeping costs in mind! If you consider the price of this setup vs just an RM bar its cost is low considering it is modular and has many options to choose from!
So why use these brackets??
Well they allow you to use the stock EVO 789 rear ARB which is 22mm OD. These are the differences below,
* OEM GSX is 18.5mm, RM is 20.6mm, This EVO bar is 1.4mm bigger then the biggest bar the AWD can currently get!!!!!
* OEM FWD is 13mm, RM is 17.5mm, the EVO bar is 4.5mm bigger then what the FWD can get!!!!! AND...........
Evo Aftermarket bars can be found in 24mm and 25mm which is a WHOPPING 6.5mm and 7.5mm bigger! THATS A HUGE BAR! These are normally adjustable and come with either 2 or 3 mounting points for the drop links to adjust the stiffness of the bar.
********** NOTE THAT FROM 2022 I can supply 24 and 25mm bushes also to use in the same bracket due to the redesign and bush design **********
Very cost effective considering the RM bars are 200 alone and no choice of upgrades from there on.
So with these you can have many choices of upgrades
* They work with OEM lower arms and as seen my arms, should also work with Pauls also
They will be a direct bolt on for both FWD and AWD rear frames and will come with everything you need including new hardware bolts and bushes, all you need to buy is a used EVO rear bar! Should be fairly cheap! Just make sure its from a 789 as that's the 22mm version,
The brackets will also be black anodized for a stealth OEM look to finish the item off. If you want to use a bigger bar from the beginning and can get a used one let me know as i can supply the bushes in 24 and 25mm.
Price is TBC for 2022
in PayPal please include these KEY DETAILS FOR ME PLEASE *****
***** FULL ADDRESS TO SHIP TO INC PHONE NUMBER
FWD OR AWD
Thanks all
Bobby
Notes, if you have the spare tire well you will need to lightly dink it to allow the bar to recess into it, see picture to see this, it is not alot.
( pictures are proto type versions ONLY ) the printer versions are of the final revised design
FWD.
AWD.
@Hickory-NC-2Ggsx
@rival
@Black95TSIawd
@MarineTalon4life
FWD OR AWD
Thanks all
Bobby
FWD.
AWD.
@Hickory-NC-2Ggsx
@rival
@Black95TSIawd
@MarineTalon4life
