gijoe985
- 562
- 20
- Dec 13, 2007
Grandview,
Washington
Hello all,
We wanted to start a new thread for our high school shop project that has been sitting for the last half year. You can see our old threads here and here.
We have the car turning on now. We've got our timing correct and we have good compression on all cylinders now. Today when we turned the engine on it ran smoothly, but at 1600rpms. It ran well for a couple minutes, but then began to have some hiccups here and there. Eventually the idle lowered some and the idle became rough and then it just died. We tried restarting it and it idled ok and then again eventually died. Wideband originally showed us right around 14. The last time we ran it it was idling at 15:1.
We did a boost leak test and thought things looked ok. Though the psi gauge we had (attached to air gun) may not have been working well. How long does it take to pressurize the system normally? We were pumping in 50psi for 10 seconds or so and that seemed like overkill. It would hold some pressure, but again, I'm not questioning how well that gauge is reading. Sadly maintenance just came to service our compressor, so we may not have air for a few days. But we didn't hear any leaks when we pressurized it as high as we felt comfortable.
I know that the BISS will need to get adjusted, but I was waiting until it seemed to be running better.
Thoughts?
Thoughts?
