New Product: Hurst/Ratchet Shift Lever and Bracket
MorrisonFab
Supporting Vendor
315
1,073
May 28, 2017
Johnson Creek, Wisconsin
Low profile shift lever and bracket for use with the Hurst Promatic 2, B&M Pro, and other similar ratchet shifters for a DSM. Fits 1g/2g/FWD/AWD turbo A/T models.
The cable and linkages that came with your ratchet shifter should be tried first, but if they don't fit, the Hurst 5008555 style cable with a 10-32NC threaded end and B&M 80638 style swivel/linkage and will.
We are working on expanding the compatibility of them so if you’re interested in test fitting, let us know. If it doesn’t work, we'd of course refund 100%.
http://morrisonfabrications.com/product/dsm-hurst-ratchet-shift-lever-and-bracket/
A big thank you to Thomas DaSilva for measurements and test fitting during development!
Additional shift levers and brackets we offer:
1g Auto Shift Lever and Bracket
2g Auto Shift Lever and Bracket
Helpful thread that has an overview and compatibility information: http://w4a33.com/wiki/doku.php?id=ratchetshifter
Cheers,
Matt and Samantha Morrison
www.MORRISONFABRICATIONS.com
Which application work for my setup?
1G car with 2G aut trans, Hurst Promatic shifter
The Hurst/ratchet shift lever and bracket :)
Luckily that worked out to be interchangeable for all turbo DSMs and options.
