1G High idle
Lancer_lover
165
32
Apr 18, 2017
kristianstad, Europe
So this happend before my ecu whent out the car started to rev very high at cold start then it died. But it got a new ecu and i fixed the fuel but now at idle it work you can rev it high without any stuttering .but as soon u put the clutch down it goes up in rev ? So anyone know what i cud be ?
With an non-turbo car you have less places for vacuum leaks but it's still all about making sure you have none and that the ECU, Idle Position Switch, Idle Speed Control motor, Basic Idle Speed Screw, Speed Sensor and Fast Idle Control Valve are working correctly.
With an non-turbo car you have less places for vacuum leaks but it's still all about making sure you have none and that the ECU, Idle Position Switch, Idle Speed Control motor, Basic Idle Speed Screw, Speed Sensor and Fast Idle Control Valve are working ill try to check the ecu idle position switch is it the black one with 4 pins ? Located next to the trottle body ?
I'll try to check the ecu idle position switch is it the black one with 4 pins ? Located next to the throttle body ?
There are two sensors on the 1G style throttle body the Throttle Position Sensor and the Idle Position Switch. The TPS is the black 4 pin rheostat and the IPS is the single connector threaded switch above the pulley.
Thank u ill start and check them do u thin i will notice anything by pulling out the connections to se what happening ?
You will want to check them with a multimeter and make sure that the TPS is outputting the proper voltage at both fully closed and fully open. I do not have a link for the FSM on this but that's what should be followed to adjust the throttlebody correctly.
I'll check it with a multimeter again.
Only thing i noticed was 3rd pin didn't show anything.
i'm gonna try again today. I even took the cable out from the oxygen sensor to see if there was a difference but didn't notice anything, no cel either.
I did as the hayes book said and got this
Numbers first pin 0.60 ohm and second pin 4.17 is this good ?
And the second pin
Reporting back now ecu is fine but my IAC is wierd! when i have the ignition on it makes like 3 or 4 fast rattle snake sound and if i turn the ignition off and try to do it again it doesnt do that ? Md number is E9T15292 and i took it off and that long thing was moving up and down only once and i tried again but nothing happend ... today it idle att 1500 RPM went domw to 1300 and after a hard rev it went down to 800 then back up to 1300 ? Really annoing
