motomattx
- 3,955
- 1,621
- Dec 9, 2010
wampum,
Pennsylvania
On a side note, Im now thinking of going to IFO this weekend too now that you mentioned it, usually go to the Sept one, haven't been to the spring one yet.
I have checked the fpr in the past and with the basic method of sucking on both nipples(I had too)return and vac, I didnt notice any leaks. Once i get home i will swap the fpr regardless and try to make up a line so I can remove the inline 255 pump. Then I will idle tune it correctly before I test drive...I will update asapIt's running lean at 4K, 600hz, 21 afr. IDK what it is. Injduty bounces around when it starts running lean. Did you check the stock FPR?
Make sure FPR isn't torn and get the idle dialed in correctly.
Your target rpm is 900 but it's idling around 1100
Throttle cable is too tight - 1% most of the time
TPS is off - Should be .63 off throttle
AirflowperRev is too low - Should be .25
Then tune cruise. Watch the Fuel Trim demo on ecmlink's site. http://www.ecmtuning.com/demos.php
I'll be sure to let ya know if I can make it. I have a few friends going but I cant go look at other people's toys when mine still needs attentionOn a side note, Im now thinking of going to IFO this weekend too now that you mentioned it, usually go to the Sept one, haven't been to the spring one yet.
Thats exactly when I want to go, when my stuff is sitting!I'll be sure to let ya know if I can make it. I have a few friends going but I cant go look at other people's toys when mine still needs attention
Sorry to hear that. Hope she’s ok.I won't be able to get to the garage tonight. Girlfriend is sick in the hospital. I'll update once I get back to the garage.
Again thanks to everyone for brain storming with me. I'll talk to you guys soon
