Anthony Boni
5+ Year Contributor
- 213
- 23
- May 13, 2018
Wrightstown,
New_Jersey
I have a G4CS block with some cylinder wall damage after the previous owner goofed and set the incorrect piston to wall clearance. I’m picking up a 4G63 block without the main caps. My plan is to use the 63 block with my G4CS crank (it’s a 6 bolt 100mm crank, for those who may not know) in the 4g63 block with some stroker pistons to make a 2.3l stroker. Because the block I’m picking up doesn’t have the mains, can I just use the main caps out of the G4CS? I’m getting ARP main cap studs and a kiggly girdle, so I’m going to need a line bore anyways. Thanks!
