Fuel rail -6 return fitting problem
K_81_K
58
14
Jun 1, 2018
Ontario, ON_Canada
Having a slight issue getting my fitting and adapter to clear the timing cover
Is there a way around actually cutting the cover?
I’d rather not have to go that route
Any help would be greatly appreciated
Thanks!
You will possibly get away with a forged 90 but they are more expensive then the fast flow ones. I have seen some do this and it just touches the upper cover a tad, on my aftermarket rail i had to opt for a banjo type fitting as it was longer and a forged fitting would not work well
Interesting. I have the fuelab regulator kit, and while it's a tight fit, it clears with a few mm. Was your return line/fitting from a kit? Is the engine a 6 or 7 bolt, and what timing cover bits are being used? Bad pic for reference, if you'd like a better view I can take one.
You can always get a low-pro 90* fitting, but it will cost a bit more than the full-flow ones.
The 91-94 1g rail is a few mm shorter then the 2g rail. Besides the slightly shorter length, the outlet of a 1g rail will need a different adapter while the 2g is the same on both sides.Actually the 90 rail is the shortest of all but won’t work with the 91-99 TPS due to the flange angle. I run a 91-94 rail so I can run a timing cover on my 2g without the 90° rubbing.
More information here
https://www.dsmtuners.com/threads/1g-vs-2g-fuel-rail-physical-difference.57354/
I'm using a 90 degree fitting like this and it just touches the timing cover.
Do you have a pic of that installed?
Thanks btw it’s exactly what I was hoping to find out would work but still can’t find one anywhere
Scratch that
Found at RTM
Thanks everyone!
Scratch that
Found at RTM
Thanks everyone!
Thats the wrong one, thats a 3AN and you will need a 6AN
