YungTlon
5+ Year Contributor
- 104
- 12
- Mar 6, 2018
Pueblo,
Colorado
I'm guessing you can't get the cable out of the middle?
Well shit that’s no good!Yes the cable should just slide out. It has small guide pin but nothing holds it into the actual casing besides the nut you already loosened.
And uh oh that’s not good yes I can spin it, and yes I did a dig and the sensor popped out because where it bolts in the little bracket had fallen off!its possible the cable has jammed inside the sensor due to the cable being bad. can you spin the current sensor?
im guessing your replacing it because your speedometer doesnt work?
Well sh** that’s no good!
