1kick
5+ Year Contributor
- 84
- 17
- Mar 27, 2018
Santa fe,
New_Mexico
So I ended up having to do another head gasket and I figured while I'm in there I would do bearings and rings at the time it was a good idea when I pulled the bearings they were badly worn the engine has 156k on i went with clevite bearings and wiseco rings had the crank worked on bearing clearences were a little on the tight side and with in spec honed the block everything looked great put it all back together and it started up perfect no wierd noises my oil pressure was back drove it normal for the first 800 miles then started getting on it a little at about 1400 miles I started to hear my tob starting to make noise along with a clicking coming from around the front crank I think the plate is hitting the crank sensor I never had these problems before did I do something wrong ? And how long do you guys think this rebuild will last I'm new to working on the 4g63 engine but have been working as a tech for 4 years
