- Thread starter
- #26
Got Grip
20+ Year Contributor
- 289
- 261
- Sep 17, 2002
Philadelphia,
Pennsylvania
I'm interested in the DBW setup as well. You could do some sweet traction control if you have wheel speed sensors.
That's certainly an option and I have an Elite 2500T so I could do traction control with that easy enough. If track prep is anything like last year though, I likely won't need it at Drag Week. I will be considering dialing it in though beyond drag week and I'm also interested in what I can possibly do with it if I put the dog box back in the car.
I’m in. What a build
Thanks!
Very cool!
In the past, reichen had issues with his 1g towing a trailer. Killed is converter/trans.
Granted it was a small tiny uhaul, but heavy none the less. I hope you ate planning something no larger and heavier than absolutely necessary.
In the 50's there was a pop-up camper, that bolted to the bumper on each side, and use a single large caster to support the weight and maneuverability. With almost zero drag or mpg degrease.
One other thing you have going, is the possibility of a lockup torque converter. I hope you are planning on using that feature.
Thanks for the input. I'll have to contact Reichen to get some more info from him. I'll likely be building a box on an open trailer from Lowe's like we did for my dad's car this past year (picture above) but I'm still shopping for the trailer now. I'm also adding a fairly large transmission cooler with a fan to help combat the increased temps. A similar cooler worked on my dad's car this past year with a heavier car, a trailer, a lot of hills and a way looser converter than what I'll be running. I'll definitely be keeping an eye on it and doing a lot of testing before hand.
