Where does this bolt go?
John Mark Dongon
94
5
Feb 7, 2019
Stockton, California
I'm pretty sure it goes somewhere under my cars engine
What you have there is part of what is known as a wire hose clamp. You would see this on coolant hoses and the rubber portion of the fuel inlet for the tank.
@John Mark Dongon
Don't worry about that bolt, that is just a bolt for a wire hose clamp. In near future, you will probably want to replace it with a better clamp, such as zebra clamp, a t-bolt clamp or so (It would be depending on where you use it).
Just in case, if you wish to use that stock wire hose clamp, that type of stock clamps are used on intake pipes/hoses, upper/lower radiator hose or fuel tank hose.
