- Thread starter
- #176
b00st3d
- 468
- 373
- Jan 13, 2005
Yukon,
Oklahoma
Got some time in the garage this week and got some things taken care of. Paint matched. Still need to do the cage but this is looking a lot better.
They are the pin locations. They still need cut down to the final length and the actual pin welded in.Drool... The volk stuff is sooo legit. But I should probably fix oil leaks and rust before I start blowing money!
Also, what are the vertical pieces on your tubular front left/right side in front of the motor/trans mounts? They look like they go almost to the hood. Hood pins?
Drool...
About 2.5"Looks amazing! How much clearance is the 4” gonna have when sitting on the ground?
what caused the FD to not fit after the galant knuckle install? reason i ask is becuase i also have a 2g with those knuckles with the brembos on and am looking to purchase fd rimsA little progress. The FDs didn't fit after I installed the Galant knuckles so i picked up some Evo wheels with a set of hoosiers.
View attachment 281136 View attachment 281137 View attachment 281138
