Boostin Performance Spring Special!
Boostin Performance
396
200
Jan 7, 2014
Hoffman Estates, Illinois
Spring is right around the corner! There’s no better time then now to get your vehicle ready for the season. Whether you are looking to have your clutch replaced, have new brakes installed, or even have your car tuned to ensure it is running at peak performance, we’re your one-stop shop for all your vehicle needs.
We are offering 10% off of the following packages!
Boostin Performance Brake & Rotor Packages
Includes:
-Inspection of Braking Components
-Replacement of Brake Pads (StopTech, Hawk Pads, etc)
-Replacement of Brake Rotors
-Brake Fluid Flush
-Installation
Boostin Performance Clutch Packages
Includes:
- Labor to replace your clutch
- Clutch of your choice (Competition, Exedy, ACT, etc)
- OEM Flywheel Resurfacing (when applicable)
- OEM Throw out bearing replacement
- Drivetrain Fluids
- Clutch Fork Stop (when applicable)
Boostin Performance Tune Up Packages
Includes:
- Replacement of Spark Plugs with NGK Performance or OEM plugs
- Cleaning or replacement of air filter
- Boost leak test
- Replacement of engine oil & OEM Engine oil filter
- Transmission, transfer case & rear differential fluid flush (*w/ SST filter replaced if applicable)
- Replacement of accessory drive belts (when applicable)
- Tire rotation
- Full vehicle inspection includes checking brakes, rotors, suspension components, etc. to keep you updated/informed of other possible maintenance issues that may need to be addressed.
Sale Ends March 29th, 2019
Contact us for details or to schedule your appointment!
