Yesterday I got the interior Finnished. I know it has nothing to do with performance, but I built the car for show and go. Some do not like, but any who, LOL.
Very nice
Now im done with this piece :) before
And after ignore the black spots in reving them and gonna have gray vinyl on it to
And vinýl rubber to
1 wire Saturn Alternator swap. Using OEM tensioner in stock configuration with homemade bracket added. Only did grinding to the alternator case itself not the front case or block. More then enough clearance for tensioning the belt.
Packed up my car with a 512 mile relocation plan for Winnipeg mb Canada for a new job offer I accepted
Hey there. I made a template I could send you guys. It will fit perfect. you just have to get it milled. Look at my build thread, you will see.
Thanks for offering i got something in the works already should have it all set by next week
Finilly installed my vr4 calipers. Still need to bleed the system.
Prepping for a couple 6 bolt builds today.
I should have started a build log, but this is what keeps me busy. :thumb:
The son's build gets the regular stock rods and pistons. Mine is getting something different. Stay tuned.
And vinýl rubber to
What glue did you use? I tried the 3m contact cement I usually use for fabric, on vinal, and it made the vinal look horrible.
Eventually I will do away with some of the gauges seeing as how the Mxs with monitor a lot of what's going on. But until I learn how to fully use it I will keep them.
