Sephent
- 61
- 2
- Feb 18, 2016
Medford,
Oregon
Hey all. So I just picked myself up a 95 gsx. Only info I got was "it was running fine. Then it died and will not start" Claims it would crank but not start and suggested fuel pump. Did not sound like it has been sitting for long, but tags have been expired since 2009.
I was just curious of any tips on what to check and replace overall for a car like this? I have read and will continue to read threads on similar issues. Sounds like crank sensor and cam sensors going bad trigger the auto shutoff relay. But if it is suggested to take off the head and investigate things, etc. Just let me know. I think I am going to change the oil and put fresh gas in before any startup attempt is made.
Just hoping to get some advice with this car on what to look for overall it is my dream car and glad I finally got it. Now time to make sure nothing is half assed on it. Only 90k miles also.
Thank you in advance. And as stated before. I know I have a lot more research and reading to do. Which I plan on doing thoroughly..
