lowered02eclipse
- 0
- Dec 22, 2017
sun city,
California
Im pretty stuck right now and haven't got help from the 3g eclipse eclipse forum.
I have an 02 eclipse rs 4g64
I recently installed an ACT Mb1-xtss clutch and act throw out bearing. I can't put the car in gear while running. I didn't put the disc in the wrong way as I had a reference picture that it was in the right way.
I did get the stock flywheel turned for the first time and not sure how much they took off.
I've replaced master and slave cylinder and checked for leaks through the lines and found nothing.
I bled the slave using a tube to a bottle and the fluid had no air bubbles so im lost.
It seems like the clutch fork isn't pushing the pressure plates fingers enough to disengage the clutch.
The last clutch I had installed was an exedy and it was also very squishy pedal feel but I was able to drive it around at least. The only option right now that I have is getting a longer slave cylinder rod? And help would definitely be appreciated.
