1G No start+coolant leak
eclipse'97
Apr 28, 2016
Regina, SK_Canada
Hey everyone I am abit new to the 4g63 as all I have ever worked on is my other 97 eclipse rs.
I bought a 91 Plymouth laser rs turbo last month and it ran great. It's an automatic & is completely bone stock other than it being straight piped. Besides that I don't know if the internals are stock or not (yet).
The car over heated on me (didnt shut off on it's own but temps got high so I shut it off judging by the stock gauge)
The car takes forever to start now but will start after a very long time of cranking. Once started it idles on it's own and revs up smooth.
I did a compression test and my results came back two times with two different gauges the same.
#1-60psi #2-30psi #3-20psi #4-40psi
Now I really think the car shouldn't start at all with that low of a reading
The car doesnt start any easier with starting fluid either.
Theres also a bad coolant leak on the drivers side . It seems to leak more when your trying to crank the car but still leaks just not as much when just sitting there . I suspect water pump but wouldnt the timing belt be wet if the waterpump gasket leaked?
Besides that I know the waterpump isnt the reason shes so hard to start aswell so I'd need to figure that out aswell.
Any thoughts would be appreciated.
I know its probably time for a rebuild.
I just want some other opinions first! Let me know if I missed any important info that may be useful to help me diagnose this!
Thanks for reading!
The head is warped, the head bolts are stretched, the headgasket is leaking because of that, likely the piston rings are now damaged also, time for a rebuild. Never continue to run any engine when its hot, it will get you nowhere at the end of the day, you will still end up walking and it will cost alot of money to fix.
Yeah normally I wouldn't run any motor when there in a bad state like it was but me and my girlfriend were stranded on the highway in the middle of the night on Christmas in about -35°C :idontknow::cry: so we had no other choice but to let the car cool down and then drive abit stop and repeat until we got somewhere warm
must have overheated it real bad to get the piston rings stuck, sounds like thats what it is. If starting fluid didnt help and the compression is horribly low that must be what happened. You can try fixing the leak and driving the car and see if the rings unseize themselves. What will it hurt to try?
second that.
30 psi compression reading is low af, how many engine rotations are you doing when your're checking the compression? should be 5 "puffs", all plugs removed. some people say throttle plate open, ive never noticed a difference open or closed.
The rings arent stuck, they are burnt up and have lost their tension against the cylinder wall, as in "now me and the mad scientist have to rip apart the block and replace the piston rings you fried" burnt up.
second that.
To do a proper compression test you crank it over until the gauge quits moving any higher, no matter how many puffs that takes, the "X" amount of puffs thing is an old urban legend that likely started when compression tester instructions would say "crank the engine at LEAST X amount of times to get a good reading" and somehow that ended up translating to ONLY crank the engine "X" times.
well, when I took my ASE certifications and went to the best technical college in the nation that has been cranking out techs for over 100 years for my associates degree in automotive technology and repair, we were taught 5 puffs.
Doesnt matter really, something like that doesnt have alot of thought put into it from an instructor, they just teach how they were taught, doesnt make it right. Logic should tell you that if a given cylinder with valves sealing it is only capable of holding 50lbs, it doesnt matter how many times you crank it, it would leak everything over 50lbs, however if you only give it "x" amount of "puffs" because you cant quite count them and its not enough then you will end up with a lower than actual reading and tear down an engine chasing a problem that doesnt even exist. Theres no point at all in adding in the possibility of error for nothing to gain at all just to carry on urban myths. Read step 8 above where it says to crank the engine at least "x" amount of times "or until the compression stops rising"
I concur. Do the test again. May not tell you anything but it's free and it's quick.
For example this is a jeep 3.7L, the engineers specify 3 revolutions. So general specs are just that, general. If you don't get what you need in 5 puffs, something is a miss and you should probably do a dynamic compression and leak down test.
These reasons are why every major manufacturer that I have worked for over the years now wants a leak down test on top of a compression test before determining if the engine needs opened up! too many variables with compression tests and how people perform them, if they are done where you allow the tester to max out as far as it can, its accurate, otherwise...
Again, a bad valve is only going to hold so much pressure no matter how many times you crank it or for how long, you could crank it for two days and if its only capable of holding 20psi then its only going to hold 20psi man, same for the head gasket, piston rings, etc. It just doesnt make any sense at all to do anything else, a leakdown test will tell you where its leaking, a compression test will tell you if its leaking, thats why a leakdown only comes after a bad compression test in the industry.
On an engine with alot of valve overlap such as mine three puffs wouldnt cut it for a good reading, a car with mild cams who knows, it might work it might not, why chance it? wheres the advantage?
SMBDSX, you can do whatever you want really, as an experienced dealer tech, I can tell you that everyone that I have worked with will do it the way that I suggest, but you really shouldnt advise others to do it your way just for the fact that it invites user error if nothing else. Im not really sure why your fighting this or why your insistent on being right??? are you somehow suggesting that what I am saying is wrong or would give false readings? if thats your thought I would like to know your logic behind it. I have a goal here, to pass along good knowledge to other members here, Im not sure what your goal is?
It was only YOUR response to my suggestion to the other member to make sure he's cranking it over more than a few times. 30 PSI was low, so I suggested the standard practice of 5 rotations to see if the reading would change. Its my understanding that his engine is stock and this is his starting point. 5 cranks should be adequate in his case. Your engine is not stock. My feedback was tailored to his situation, not your engine. If it was an engine with high lift, long duration cams my suggestion may have been different, but that's not what this instance called for.
You and I run the same intake manifold, the same rods, and probably very similar if not the same pistons. Don't know what cams you have because it says custom, but I can tell you that with FP cams in my engine, 5 rotations puts me well into the 180 psi range. If it did not, I'd be concerned.
You seem knowledgeable, but tbh, I don't know your education. I know what I've been taught by 2 years of schooling by many ASE master tech instructors, the society of automotive service engineers, and experience working in the field. Stock engine= OEM diagnostics. So 5 rotations should be plenty. On top of that the mitsu service info even specifies blocking the throttle open. which I've observed to have no effect, but hey it couldn't hurt. And realistically I believe the 5 rotations is more about consistency than anything. GM, Jeep, and many other manufacturer info will simply state it should be over 100 psi and less than 30-percent variance between cylinders. So as you mentioned, compression is more of a quick check. I guess I'm not saying your wrong about cranking it over more in certain situations if the engine is altered from stock, but I don't believe that 5 rotations is an urban myth. It is considered standard practice in most OE literature and general instructions published by alldata, AC delco, and others.
And in the case of say the jeep, that I posted the service info for, they want 3 rotations, which is likely for a reason. You may be able to get a higher reading by cranking longer, but now you are not comparing the specifications provided by the manufacturer and the test may not be accurate. So there is a time for general specs, manufactures specs, and in the case of most of our engines if we are members of this forum, a time for informed experience to dictate some of our testing.
mitsubishi doesn't state a number of rotations. i think any FSM that does, probably puts a # of rotations for dumbass people that don't have the common sense to stop cranking when the gauge stops moving.
I didn't say the mitsu fsm does, I said it only states to block open the throttle, which iv observed to make no difference. The prior posting I sent was one example that does state a number of rotations. only as an example that there is literature that specifies even less than 5 rotations sometimes. So im not sure what your point is dusty.
If you're truly interested in what I think, here is my other thoughts. If you crank, and crank, and crank, you have no frame of reference. unless you're counting the cranks each cylinder takes to make the end compression reading. Cylinder contribution comes into play when thinking about drivability concerns. think about when you do a cylinder balance test. (kill spark momentarily to one cylinder at a time with the engine running and then note the RPM drop. That determines if cylinders are contributing equally or not.)
so if during a compression test one cylinder can make 165 psi compression with 5 strokes and another can only make 135, you would now make a note of that cylinder and determine the next steps necessary in diagnosing the issue. I would bet if you cranked the engine over longer, that 135 psi cylinder may be able to inch a bit higher, but now the variables of the test are no longer the same.
In fact, when working at Honda I saw this technique used many times and even the engineers on the 1-800 line recommended this when a tech was doing engine performance/drivability concerns.
If you're familiar with identafix which is another call center where people get paid to do nothing other than help shops and dealers solve problems over the phone, they also have recommended the compression tests be performed in this manner. Identafix has even mentioned to another one of my employees that ideally the first reading indicated on the gauge should read at least half of the final reading in a properly functioning engine. This is not always the case, but its another one of those rules of thumb to be aware of.
I've also read 6 rotations or until the gauge stops increasing. So in summary, I think different methods for different situations, as I had mentioned before. Experience, education, and application, and resources are keys to proper assessment of engine health. Not saying your wrong in general, and it looks like you have a well built DSM, so you must be doing something right. But I am saying that 5 puffs is not an urban myth, and many OE service info specifies a certain number of rotations often times even less than 5. In which case, if that procedure is not followed, you are in fact doing it incorrectly.
