Resolved 2G Factory Boost Control Solenoid part number
I believe it’s the same as the EGR solenoid except that it has a restrictor in the bottom port. 1g and 2g BCS are different looking so the part number is most likely different. The one above is a 2g
For some reason I have a couple EGR solenoids laying around and they are different than what you have there, never thought to search by that part number, was looking for a Mitsubishi number and having no luck. I'll try K5T47698
Luv2rallye, not trying to argue with a wiseman but that part number comes up as the '96-'97 evap solenoid. For the BCS itself (along with the little bracket it comes with), the part number I can see is MR127560. Or just MD145201 for the solenoid unit itself. Here's a pic; unless the database I'm using is outdated but I've used it hundreds of times and always got the right parts. I think it's based off CAPS.
Those Mitsubishi part numbers were what I was looking for, unfortunately they aren't even in the OEM online parts catalogs anymore.
I was able to find a couple used using the "K" number, fingers crossed that they are any better than the one I've got in the car.
