November Porting Special @ Boostin Performance
Boostin Performance
396
200
Jan 7, 2014
Hoffman Estates, Illinois
For the entire month of November, we are offering 5% off our Porting Services!!!
Porting is a detail often overlooked or forgotten about, but not at Boostin Performance. Buying the best turbo on the market will only get you so far. Cast components tend to be rough which can cause excessive turbulence and ultimately rob power from your set up. By removing these irregularities and smoothing the casting, you'll increase the flow capabilities of your set up!! Porting your cylinder head, manifolds, and/or turbocharger is a detail you don't want to ignore as the smallest detail can make a difference.
Extreme attention to detail is taken with our porting services. With our intake manifolds, the runners are gasket matched, the porting goes deep into the runner, and all of the bumps and irregularities on the inside of the plenum are removed or smoothed out. A Ported Stock Intake Manifold also serve as a stealthy way to keep that stock appearing engine bay look.
Our Porting Services include, but are not limited to:
-Turbo
-02 Housing (Cast Only)
-Exhaust Manifolds
-Intake Manifolds
-Throttle Body
-Cylinder Head Porting
Sale ends 11-30-2018
Contact us if you have any questions regarding this service such as what can be ported, and pricing!
