Eclipsanitta 420a
Installed a set of digital gauges on the left column - cheapo ones from CNSPEED, turned out to be showing quite accurately actually. Water temp, oil temp and volts. Still havent figured where to put the sender for the oil temp other than placing a T on the OEM oil pressure unit.
Very cool!!! Are Eclipses common in that area?
Noo, not really :D I think there are about 5 in my city with mine being the only one imported from America, all others are EU spec. Total in the whole country wouldnt be more than 200-300 in my opinion... even 100. Aaand I think there's no more than 10-15 imported from USA :)
RX-8 rims done! :D
Big Brake upgrade - Dual pot calipers, 294mm Zimmermann discs, ATE brake pads, ATE TYP200 brake fluid
Gearbox decided to suicide 2 days later after the brake upgrade - the differential pin flew out of the casing and got all the oil down on the street. New gearbox from a PT cruiser and we're rolling again.
