2G Which Front Axles is it ?? LOL
Prince2King
Sep 27, 2018
Hollis, New_York
Hey Guys (im a noob)
Im converting my 2G Spyder non turbo from Auto to Manual......
However, my mechanic and I are stuck on which axles to use...he already tried 2 already.....
(P.S since Im here what is a good cold intake would you guys recommend. He told me to look for
that as well)
All the parts i found from Cardone.com are listed below
Front Left
AWD and w/ABS and 2.0 Liters and w/A.T.
60-3375
Front Right
60-3274
Front Left
AWD and w/ABS and 2.0 Liters and w/M.T.
60-3375
Front Right
60-3145
Front Left
AWD and w/o ABS and 2.0 Liters
60-3121
Front Right
AWD and w/o ABS and 2.0 Liters and w/A.T.
60-3280
Front Right
AWD and w/o ABS and 2.0 Liters and w/M.T.
60-3146
Front Left
FWD and w/ABS and 2.0 Liters and Exc. Turbocharged
60-3164
Front Right
60-3166
Front Left
FWD and w/ABS and 2.0 Liters and Turbocharged and w/A.T.
60-3261
Front Right
60-3275
Front Right
FWD and w/ABS and 2.0 Liters and Turbocharged and w/M.T.
60-3264
Front Left
FWD and w/ABS and 2.4 Liters
60-3167
Front Right
60-3145
Front Left
FWD and w/o ABS and 2.0 Liters and Exc. Turbocharged
60-3103
Front Right
60-3104
Front Left
FWD and w/o ABS and 2.0 Liters and Turbocharged and w/A.T.
60-3277
Front Right
60-3262
Front Right
FWD and w/o ABS and 2.0 Liters and Turbocharged and w/M.T.
60-3263
Front Left
FWD and w/o ABS and 2.4 Liters
60-3148
Front Right
60-3146
66-3375
Front Right
AWD and w/A.T.
66-3274
Front Right
AWD and w/M.T.
66-3145
Front Left
FWD and 2.0 Liters and Exc. Turbocharged
66-3164
Front Right
66-3166
Front Right
FWD and 2.0 Liters and Turbocharged and w/A.T. and w/ABS
66-3278
Front Right
FWD and 2.0 Liters and Turbocharged and w/M.T. and w/ABS
66-3264
Front Left
66-3275
Front Left
FWD and 2.4 Liters
66-3167
Front Right
FWD and 2.4 Liters
66-3145
What transmission are you using? and do you have antilock brakes? I would be looking at the front right and front left 2.0 with turbo m/t and with abs.
No abs, 99 GST (turbo) coupe tranny...
You should be able to use both the non abs and abs axles from 2.0 fwd turbo. Only difference is the tone ring for the abs on the outer cv joint. My car was originally a fwd non turbo auto. I swapped it to a manual and I ordered fwd 2.0 turbo abs axles and they fit fine.
Dude I PM'd this info to you like a week and a half ago.
For a 2g gst manual transmisson, there are only 2 versions on each axle, 1 with abs, 1 without.
here are the part numbers.
part # MR165587
Eclipse. 2wd. 2.0l. Left side. With turbo. Gs-t, without abs, manual trans.
part # MR165588
Eclipse. 2wd. 2.0l. Right side. With turbo. Gs-t, without abs, manual trans.
part # MR165589
Eclipse. 2wd. 2.0l. Left side. With turbo. Gs-t, with abs, manual trans.
part # MR165590
Eclipse. 2wd. 2.0l. Right side. With turbo. Gs-t, with abs, manual trans.
I know you did dusty, but my mechanic said it didnt fit....He said he tried 3 out of the 4 axles you listed.
I know if hes using OEM or Aftermarket axles....I hope that wouldnt be the issue
he's an idiot then, cause i looked up the parts with Mitsubishi ASA and even checked to see if the hubs were the same for the gs spyder and the gst spyder.
Did he say that its not fitting in the transmission or the hub?
cause the hubs are the same, the gst spyder uses the same transmission and axles as the gst.
if you have the same hubs and transmission as the gst and gst spyder, there is no possible way that the axles could be different
make sure the axles your getting have 25 splines on the outer joint and 27 on the inner (transmission side)
go to napaonline.com and search the part numbers i gave you. it'll bring up the right axles.
