2G Tow strap mounting
ileagleracing
Supporting VIP
328
191
Sep 27, 2007
OKC, Oklahoma
After mangling my strut tower bar & radiator frame structure winching the car on the trailer, I need to mount a tow strap. Any suggestions as to where to put it?
I would try and get a bracket as close to the frame rail as possible where the factory crash bumper mounts. You could weld something on to hook your tow strap too or maybe bolt something on.
Throw a towstrap around your front engine mount next time you need to winch it maybe? or weld a tow hook onto your factory crossmember?
Ive used Rennline universal kit, comes with a nice tow hook that screws into a mount which is bolted to my crash beam.
Ive been towed many times off track with out a issue, even with dragging the brake to keep tension in the tow line.
The car only rolled freely 2 out of the 3 times I used the winch this year.
I'm going to try this, worst case I mangle a crash beam?
I do plan to replace the bolt that came with the strap for a longer one.
Me and @greengoblin was discussing this not long ago, I got a strap I want to use but then I bought a wire with a hook i might use instead, Kevin liked one that pulled out and retracted back in once not needed.
Is that just mounted on the fiberglass bumper? If so, I don't see how that could possibly hold up, especially if the car doesn't roll freely.
bolt that strap to the frame rail. no good to just fiberglass
you might have to weld its bracket to the rail if you cannot find a decent spot to bolt it down
What about a homebrewed job that uses and old junkyard seatbelt that could retract when not in use? a seatbelt should be cheap and easy to procure and should easily handle the load of the weight of the car on it?
on my 98 crash beam there is already a hole where I want to put the strap, but not on my 95, so I drilled one. It's some sort of plastic material, and looks to be about 1/2" thick. My new hole is almost in line with the fasteners for the bumper support attachment.
I'll test it out before I put the bumper back on.
Towers sometimes dont have the time to be very kind or delicate, they are under pressure to get the track clean up and if your strap fails they will hook up to whatever they think will hold up.
Welded or bolted brackets should be mounted as low as possible to an even stronger part of frame.
Mandy
Samuel, are you allowed to run an aftermarket crash beam in your class?
Not really, but if it wasn't any lighter than OEM & didn't provide any performance advantage, probably wouldn't get protested over it.
I made a bracket and welded it to the front of the car. Has worked perfect. Got towed 3/4 of lap around NJMP lightning after the cam sensor came loose. Worked great. Don't mind the booger welds on the stand-off LOL
Just want to add something in here,
Here in Europe we have a stricter rule on towing for tracks, MSA and FIA rules are quite tough but not without reason so here is what i whipped up recently to get around tow hooks.
For this reason i have made them fit in the oem location and zero welding to the frame, its also the strongest possible way to have a tow being in the frame rails.
I have made a front but until my bolts arrive i cannot show that mounted but this week hopefully i can get these pics up.
However i have the rear bolted up and this is what it looks like.
As you will see it fits just like oem and keeps the oem crash bar which can also be removed if not needed but the option is there. The metal wire hooks can pull alot of weight and the option of 2 is there if needed, FIA like 4 points on a car but 2 is fine.
Bolts on in the oem place and the strap feeds through and gets locked in place by the M12 bolt holding the internal mounting in place.
I got the front finished up after waiting on some bolts to come in,
This is very similer setup to the rear and uses the factory mountings, it can also use the crashbar if needed and i made some adaptors so if i ever remove the crashbar it still supports the bumper, similer to what boosted fab use to make just useful for other things also.
So this wire tow strap mounts through the tube and locks in place via the bolt again which mounts it to the chassis rails. Im going to opt to use 2 on the front because i have them to use.
I will need to make some cutouts in the bumper cover but needs must and there is not many places to mount something thats thick enough for my liking.
Its all adjustable to get it all to setup right when the bumper is on and jigged from the oem units to make sure its accurate,
Here are the pics of the front ones in place,
We finished up a design to be able to have a tow strap come out the fog light hole in a 2gb bumper. This will replace the factory crash bumper brackets but will retain the crash bumper itself with just a little trimming. Material is on order and hopefully we'll be able to start fabricating these soon. Let me know if you see any issues with the design - I'm hoping this will be plenty strong, even though it will add a few pounds to the front end. 1.75" steel tubing, 0.12" wall. I tried to run some stress analysis on the assembly in Solidworks but I'm doing something wrong and can't get it to work.
