J Fresh
- 47
- 10
- Feb 23, 2017
Vista,
California
I've got a 97' GS-T with 73k original miles. The car has been in SoCal car for all of its life...
The stock oil pressure "gauge/dial" sometimes moves to about the half way line when i first start the car and other times, maybe to the 1/4 line or not move at all. This also happens when I drive - the oil pressure line will be anywhere from the half way line to not registering at all...
Do you think the oil pump is going bad? it is original and car has 73k...
Do you think the sensor connected to the oil filter housing is faulty?
Should I buy an after market oil pressure gauge and disconnect the factory one?
