* 15x8 Volk TE37SL In Stock At STM - Blue, Black, Graphite, White, Gold!!!
STM tuned
Supporting Vendor
574
71
Feb 14, 2008
Rochester, New_York
Our shipment of TE37SL's just arrived this morning. These are the same wheels we've been running for years on our customers, and our own drag cars. Weighing in at just 11lbs each, theres not many wheels than can compete! They are all 15x8 +32, and only sold in sets of 4.
We have several sets available, but once theyre gone we probably wont see them again for another year at least.
Colors available
-Mag Blue
-Flat Black
-Gold
-Gloss Black
-Pressed Graphite
-Champion White
Pricing is $2250 shipped per set of 4 in the lower 48 states. Other states or countries will require an additional shipping charge based on location.
If you are interested please give me a call ASAP to get your set - 585-226-8226
-Austin@STM
Can we see a set on a DSM? Couple guys above saying they don't fit to well... Obviously single piston brakes or an aftermarket light brake setup (like STM's) will be needed to clear a 15" wheel, and probably coilovers with a 26" slick..
Just curious what about the wheel doesn't fit a DSM, correctly...
they 32mm offset pokes out past the fender on a 1g. you can fit a 15" wheel on a 1g dual piston brake setup.
The Volk wheels would poke out the fender worse then a stock EVO 8 wheel your saying? I know they (EVO 8 wheels) seem to protrude ever so slightly in the front, but fit closer to OEM (stock 1g) wheels in the rear. I assume, that since EVO 8 wheels are 8" wide, they (Volk wheels) would stick out even farther. Wish they were offset the other way (+42 perhaps) and a small spacer could just used if needed...
yea after looking up the specs these will stick out another 1/8th of an inch farther than the evo 8 wheel
Wow, that's kind of surprising. I remember seeing the same wheel (no sure what the offset was) on Fernado (Ostar)'s car and they didn't seem to protrude that much (I don't recall anyway).
Hey STM.. Anyway we could get these in say +38 or +40?
