ECMlink bosch lsu 4.9
tumbler
30
Feb 15, 2006
Sicklerville, New_Jersey
Can i run a bosch lsu 4.9 wb o2 sensor with link? If so, how do i wire it up?
I have ecmlink v3. If i install wb in front o2 position then i just need to run wiring to ecu and tap appopriate wires at ecu, correct?
As previously stated, you need the wideband sensor and then the gauge/"kit" that will allow you to actually use the o2 sensor. You can't really just use the sensor by itself.
You need some type of wideband controller in addition to the actual wideband sensor itself, if it was that easy or cheap everybody here would have had one a decade ago.
Yes like stated above you cannot wire the sensor directly to the ECU. You need to wire the controller then use the controller outputs wired to the ECU.
