Brad Bell
- 192
- 5
- Aug 15, 2014
Levant,
Maine
I know there is probably a thousand manual boost controller troubleshooting threads out there. But none of them have helped with my situation. Running 420a turbo. I have this ball and spring manual boost controller running between the nipple coming out of my turbo and the wastegate. However between the wastegate and the boost controller, I have a 'T' fitting that runs a vacuum line to my fuel pressure regulator. Stock wastegate spring on my turbo is 8psi, but with the boost controller installed and the screw loosened as much as possible without coming off it's boosting well over 10psi. Not sure what's wrong, tripple checked to make sure controller is installed correctly.
Thanks guys.
Thanks guys.
