Mitsu-MattGSX
- 3
- Oct 30, 2017
Pittsburgh,
Pennsylvania
I have a 98 GSX that developed this on my way to work today. At first it was faint and then it was prominent and the CEL came on. 2 days ago I had this same problem and it was just that the hose to the throttle body had come off because I forgot to tighten the clamp. I tightened it and went on my way. When I popped my hood on the side if the road the hose was clearly clamped down. I can't get past I'd say 3500 rpm without it not accelerating. I'm going to check the CEL when I limp it home later. Recently I changed the plugs wires and coil packs and had to remove the fuel rail if that means anything
