2gGst98
- 705
- 58
- Oct 3, 2010
Concord,
North_Carolina
I finally got AWD. NO RUST
Long story short, buddy of mine lost interest on his build and I now have his 92 laser RS. I have helped him with this car a lot.
-Mods I know of
Engine .040 over forged internals (i forget what we put in)
Balance shaft delete.
New head, valves, seals, beehive springs, exc
Some sort of 20g build by Justin number of years ago.
Rewired 190lb fuel pump (soon to go 255)
560cc inj
Link v3 lite (I will get full)
4 bolt rear
New shocks stock I think (I will go with feal coilovers)
-main problems
Coolant jacket is cracked under intake mani leaks coolant
Runs hot when 70*+ outside
Trans grinds bad
Drive shaft yokes bad
Suspension needs replaced
One bent rim
Now to my question
Where should I start? I need some inspiration
I have a bare 6 bolt with some rust on cylinder walls. I plan on using internals from old block. And only looking for little over 400WHP. I know I’m limited with the 20g but with cams and being 040 over, I may be able to hit it. Just looking for some help/inspiration as I’m excited to get this car from him.
-Mods I know of
560cc inj
4 bolt rear
-main problems
Trans grinds bad
One bent rim
Now to my question
