pearl4gtsi
- 216
- 2
- Jul 17, 2004
yonkers,
New_York
Hey all,
I'm in the process of working on putting my rear end back together. Since it's out, I figure now is the best time to install a sway bar. But having been soo long since I've driven the car and the fact that it'll be a totally different animal, I could use some help making the choice.
My profile is not updated as the car isn't finished yet and plans keep changing. But in the rear I have done RTM poly subframe and moustache bushings, evo 3 mechanical lsd diff, upper and lower control arm bushings, and 3kgt vr4 trailing arms. I don't have coilovers at the moment, but my eyes are set on the Ohlins by mueller.
I don't know if the front plays a role, but the front just got some LCA poly bushings and modified to fit a taller ball joint to correct roll center( I should probably do the same in the rear?)
My plans is to street the car every weekend or so and road course. I know ideally we want the cars neutral, eliminating understeer. As I understand it, the evo rear helps with that a lot. I'm not sure what kind of effect the wider track from the vr4 arms will have.
Im looking for help/suggestions as to which route to go. Adjustability is a must for fine tuning. I know there is whiteline, ST, RM sway bars... what else is there? Any first hand experience?
Thank you all in advance!
