1G Knock sensor/O2 sensor
bluelsr90
95
3
Aug 3, 2005
petersburg, Virginia
Okay so I have a 1G DSM that had a check engine light code of 31 knock sensor went replace the knock sensor the knock sensor was definitely bad it had the black goo coming out after I replaced it I unplug the negative side of the battery for a few minutes to clear the code after I clear the code I restarted the car and after about 2 to 3 minutes to check engine light came back on I then hooked up my voltmeter and realize it was still code 31 so I unplugged it check the harness for voltage i had 8.6 volts coming from the harness plug after looking around the car and I noticed that one of the black wires on my O2 sensor was rotten and not hooked up could this cause my issue
Thanks gravedigger and Allanl. Fixed the wiring no more check engine light
