sacrileger
- 288
- 43
- Jun 26, 2016
Orillia,
ON_Canada
I am replacing a 6bolt crankshaft that crankwalked on me...see here:
6-bolt crankwalk - 0.065" endplay
I have a replacement 6bolt crankshaft that I am not able to date, i.e. I cannot determine the date of the engine manufacture that the crankshaft came from. I am ordering all bearings and seals online. Two sets of everything are available for the 6bolt crankshaft. One for engines/crankshafts made up to March 1992 and then for crankshafts made starting April 1992.
For example, the rear main seal for crankshafts manufactured AFTER March 1992 measures I.D. 85mmx103mm O.D. x8mm wide and the rear main seal for crankshafts manufactured PRIOR to April 1992 measures I.D. 80mmx96mm O.D. x9mm wide.
Furthermore, the Engine Main Bearing Set is rated as Standard (STD) for crankshafts manufactured AFTER March 1992 and the Engine Main Bearing Set for crankshafts manufactured PRIOR to April 1992 is said to be 0.25mm undersize.
The motor these parts, including the crankshaft, goes into was manufactured in March 1992. What criteria do I use to purchase the correct seals and bearings for this project? The size of the replacement crankshaft or the March 1992 engine block the crankshaft goes into?
