EC17PSE
Freelancer
- 5,894
- 3,486
- Nov 1, 2008
London, UK,
Europe
Looks very nice and aggressive, make sure the mounts are strong! I mean very strong!!! Ive seen some home jobs thats pull the brackets off the chassis because it works as designed and its not nice.
Be aware if you tap that at speed on a curb it will likely rip it or crumple it due to the material, I myself have chosen ABS plastic for this reason as its used alot in this way and takes a pounding too!
So far what you have done looks great and the effort gone into it is top notch, love home aero buiilding .
As for the lower part of the splitter is to use a small rad on the front most underside to create more downforce, this will pull it down alot more then without so more bracing might be needed on the corners, if this splitter does work very well i see your corners being pulled down and since you have no corner support this might become an issue. Its not uncommon for splitters to have lots of braces, 4/6/8 to spread the load its seeing
