Mitsubishi Turbos, TD05H-16G RESULTS ONLY (DYNO/TIMESLIPS for COMPLETE SYSTEMS)
Morphius
DSM Wiseman
1,895
62
Jun 9, 2003
M-Town, Michigan
So, the intent with this, like the Holset Results thread, is to organize real world results for dsm enthusiasts that are running Mitsubishi 16G Turbos. Post info regarding your cars setup and results either on the dyno or at the track. To keep us all honest, you'll need to include a timeslip or dyno chart for your car.
NO DISCUSSION!! Don't post comments/questions with regards to anyone’s post. It clutters up the thread. This will help many of you quickly find others that may be running your setup and give you an idea on what potential it may have
TO POST HERE:
1. You must have a minimum of (1) of the following to post:
A. Photo of your timeslip
B. A dyno chart
C. A video of your strip run that shows your E/T and/or speed
2. (SUGGESTED) Please quote the 2nd post in the thread That post is intended to be a template to use to post your info. You'll just quote that post and delete the code around my name and my name/etc so it's only the template in your post. If the line in the template doesn't apply (like you are running a stock intake and on the intake mods line, just put NA) The more info you can share, the better it will inform others down the road.
3. If interested, you can post a pic of the engine bay
4. For updates to your results, please quote your prior post. Below it, add the updated components using the same format along with the new plots or time slips.
AGAIN, RESULTS ONLY, NO DISCUSSION!
DRAG STRIP INFO
60':
1/8 Mile ET:
1/8 Mile MPH:
1/4 Mile ET:
1/4 Mile MPH:
Drag strip (name/location):
POST TIME SLIPS HERE
DYNO INFO
Peak HP:
Peak torque:
Dyno (brand/type):
POST DYNO PLOTS HERE
TUNING
Self/Shop tuned (shop name):
A/F ratio:
Timing:
Boost level:
Fuel type:
Power adder (Y/N):
Power adder (Type/Size) :
ENGINE:
Displacement:
Compression:
6 or 7 bolt:
Stock short block (Y/N):
Short block mod(s):
Block mileage:
Stock head (Y/N):
Head mod(s):
Stock cams (Y/N):
Aftermarket cam (brand/specs):
INDUCTION:
Turbo:
Stock Turbo (Y/N):
Turbo mod(s):
Stock intake (Y/N):
Aftermarket intake (brand):
Intake mod(s):
Stock TB (Y/N)
Aftermarket TB (brand/size):
Stock injectors (Y/N):
Aftermarket injectors (brand/size):
Stock intercooler (Y/N):
Intercooler mod(s) (brand/size):
EXHAUST:
Stock manifold (Y/N):
Aftermarket manifold (brand):
Manifold mod(s):
Stock wastegate (Y/N):
Aftermarket wastegate (brand/size):
Stock exhaust (Y/N):
Stock cat. convertor (Y/N):
Aftermarket exhaust (brand/size):
Aftermarket cat. convertor (brand/size):
Muffler (brand/type):
DRIVETRAIN
Manual/Auto:
Stock trans (Y/N):
Trans mods:
Stock t-Case (Y/N):
T-case mods:
Stock diff/axles (Y/N):
Diff/Axles mods:
3/4 bolt diff/axles:
Stock driveshaft (Y/N):
Aftermarket driveshaft (brand/type):
CHASSIS:
AWD/FWD:
Stock shocks/springs (Y/N):
Shock mod(s):
Tires (Brand/size):
Stock subframe(s) (Y/N):
Aftermarket subframe (brand):
Stock control arms (Y/N):
Aftermarket control arms (brand, F/R, Upper/Lower):
Interior Weight Reduction - IWR (Y/N):
IWR mod(s):
Overall vehicle weight:
Chassis mileage:
POST ENGINE BAY SHOT HERE
BRIEF COMMENTS HERE IF REQUIRED. Please limit to 2 lines.
For comparison purposes, from our friends at Evolution.net:
https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/197890-mitsubishi-oem-turbo-specifications-including-flow-rates.html
Mitsubishi OEM Turbo Specifications
Flow Rates @ 15psi:
TDO4-9B-6CM2 265 CFM
TDO5-12A-8CM2 320 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
TDO5H-14B-6CM2 405 CFM
TDO5H-14G-8CM2 465 CFM
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TDO6-17C-8CM2 550 CFM
TDO6H-20G-14CM2 650 CFM
TDO7S-25G-17CM2 850 CFM
TFO8L-30V-18CM2 1200 CFM
Max Output:
TD05-14B (stock 1st gen) 275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
T25 (stock 2nd gen) 235-250hp @ ?? psi
T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi
T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi
Place holder.
Feel free to post now!
DYNO INFO
Peak HP:292
Peak torque: 264
Dyno (brand/type): STMs hearbreaker = Mustang
TUNING
Self/Shop tuned (shop name):Self
A/F ratio:10:8.1
Timing:16
Boost level:24psi
Fuel type:93 octane
ENGINE:
Displacement: 2.0
Compression:stock 1g
6 or 7 bolt: 6
Short block mod(s): Stock
Block mileage:90k
Head mod(s): Stock valvetrain with Fp2 cams
INDUCTION:
Turbo: EvoIII 16g
Stock Turbo (Y/N): n
Turbo mod(s):
Stock intake (Y/N): Y
Stock TB (Y/N) Y
Aftermarket injectors (brand/size): FIC 850s
Intercooler mod(s) (brand/size): ETS 4" fmic
EXHAUST:
Aftermarket manifold (brand): FP manifold
Aftermarket wastegate (brand/size): tial 44mm external
Aftermarket exhaust (brand/size): Custom 3" exhaust with no mufflers or cats
DRIVETRAIN
Manual/Auto: Manual
Stock trans (Y/N): Y
Stock t-Case (Y/N): Y
Stock diff/axles (Y/N):Y
3/4 bolt diff/axles: 4 bolt rear diff
Stock driveshaft (Y/N):Y
CHASSIS:
AWD/FWD:AWD
Shock mod(s): KYB AGXs on stock springs
Aftermarket subframe (brand): Stock
Aftermarket control arms (brand, F/R, Upper/Lower): Stock
Interior Weight Reduction - IWR (Y/N):N
Overall vehicle weight:3300lbs
Chassis mileage:90k
Self tuned, ran it on the dyno in 95 degree weather.. definitely had more in it but I didn't want to push it in that heat.
