420A ? About doing a compression test
screwlegg
5+ Year Contributor
34
Jan 27, 2018
Sebring, Florida
I got a 420A Eclipse that the timing belt slipped about a year ago and already put the belt spot on to the best of my knowledge. I'm just now getting around to working on it.
I'm trying to do a compression test on it tomorrow I just need to know if the car "HAS" to be at operating temperature because my car won't start it just tries to start and when I'm testing the cylinders do I take all spark plugs out or just test each cylinder one at a time and put the plug back in
It don't have to be at operating temperature. If the car don't run then you can't have operating temperature. Just make sure that you have the same compression from cylinder to cylinder. If one is low then you found your problem. Good luck. Post results.
Thanks Brembo for getting back to me so fast I guess that was a stupid question but it's better to know than not... Just one more thing does it matter about the spark plugs like I was saying in the 2nd question? Sorry just never really messed with an engine before and I don't want to open up the head if I don't need to for something I messed up on!
Yea just trying to check if the valves are bent before I open her up who knows maybe it's not the valves so o just want to check first. It's a interference engine, I didn't get to doing the test today but maybe tonight or tomorrow because I have work
YES! the 2.4 is non interferance, so depending on what block that car has in it, it can be non interference.
No need for disputing over something so silly not what I intended of this thread. But max do u know of any guides for removing a head if not a place where I can get a shop manual as thier is no dealers close by me
The best value is to buy a set of factory service manuals for a 97 eagle talon on eBay. I got a good set for $10 shipped on eBay, that's the service manual and electrical manual
Also keep an eye on Craigslist for a used motor from a junkyard car with a warranty. The 420a motor should be easier to find as a full yard pull, where as the 4g63 is alot less common to find in a regular junk yard
What I'm getting at is that its not uncommon for a 20 year old 4cyl car to have had the original 420a swapped for a 2.4 from a cloud car by now, there are several just in my small neighborhood that have been.
