For Sale 6-bolt engine parts f/s
jamel16
289
247
Aug 6, 2004
Richmond, Virginia
Hello tuners, I have some engine parts from a spare 6-bolt I have had for awhile. I know this was a running engine with roughly 10-15 thousand miles on it. I basically disassembled it because the transmission mounting point on the block had sheared off. Prices are obo but please include 3% for PayPal fees. Also please remember when submitting your best offers that some of these items are heavy and shipping can be expensive. I can be reached through PM's but for a quicker response you can text or call me at 434-941-4568
1g 6-bolt cylinder head w/ all valve train components- it also has 3g revised lifters, deck is still true and valves look pretty good. $ 210.00 shipped obo
1g 6-bolt uncut crankshaft- main and rod journals look exceptionally clean, passed the fingernail test. $ 200.00 shipped obo
Evo 8 560 injectors- I recommend replacing seals $ 80.00 shipped
ARP 6-bolt head studs- $ 40.00 shipped
Set of 6-bolt oil squirters- Buying a new set of these will run you over $ 100.00, threw these in the ultrasonic cleaner and they look great. Will need new crush washers- $ 40.00 shipped
1g 6-bolt oil pump- cleaned and inspected, no cracks or defects found. BSE kit already installed- $ 50.00 shipped
4g63 valve cover- valve cover in good condition, only defect is one spark plug cover bolt hole broken-$ 40.00 shipped obo
1g 6-bolt turbo throttle body w/all sensors- $35.00 shipped
.020 Wiseco pistons on 1g 6-bolt rods, pistons and rods look great with no defects, I would run these no questions asked.- $ 200.00 shipped
1g 6-bolt intake manifold- $ 35.00 shipped
UPDATED LIST WITH NEW PRICES, I'VE LOWERED THE PRICES TO MOVE THIS STUFF SO PRICES ARE PRETTY FIRM.
1g 6-bolt cylinder head w/ all valve train components- it also has 3g revised lifters, deck is still true and valves look pretty good. $ 185.00 shipped obo
1g 6-bolt uncut crankshaft- main and rod journals look exceptionally clean, passed the fingernail test. $ 160.00 shipped obo
Evo 8 560 injectors- I recommend replacing seals $ 60.00 shipped
ARP 6-bolt head studs- $ 30.00 shipped
Set of 6-bolt oil squirters- Buying a new set of these will run you over $ 100.00, threw these in the ultrasonic cleaner and they look great. Will need new crush washers- $ 30.00 shipped
1g 6-bolt oil pump- cleaned and inspected, no cracks or defects found. BSE kit already installed- $ 40.00 shipped
4g63 valve cover- valve cover in good condition, only defect is one spark plug cover bolt hole broken-$ 35.00 shipped obo
1g 6-bolt turbo throttle body w/all sensors- $30.00 shipped
1g 6-bolt intake manifold- $ 30.00 shipped
********* PRICES ARE FIRM***********
UPDATED LIST with sold items removed, I'VE LOWERED THE PRICES TO MOVE THIS STUFF SO PRICES ARE PRETTY FIRM.
1g 6-bolt cylinder head w/ all valve train components- it also has 3g revised lifters, deck is still true and valves look pretty good. $ 185.00 plus shipping
bo
