Geeb
384
47
Apr 6, 2016
Philadelphia, Pennsylvania
Hey guys, I have a GM SD kit (gm iat, gm 4 bar omni map)
Also, I was going to get the innovate MTX-d boost gauge/shift light to match my innovate e85 content gauge that will be going in my dash
The innovate MTX-d boost gauge comes with a 4 bar map sensor also, that I think the gauge plugs into..
The gm omni 4 bar map seemed like it would be the way to go, but now if I want to run this gauge, do I have to run the innovate and ditch the omni?
What should I do?
What should I do?
run both. the one for the gauge is just that; its for the gauge reading.
Yup, I'd run both. I'm curious as to if you should run seperate boost sources for them though, or if it's fine to use one boost source for both.
That's exactly what I was about to ask, if I should just tee it off or dedicate 2 separates..
There might be some instructions or something.
I'm still working on painting n cleaning up my engine bay and getting my wire tuck set before I drop everything in, I just wanted to know that before I ordered it, but it's on its way now LOL
