Geeb
- 384
- 47
- Apr 6, 2016
Philadelphia,
Pennsylvania
@lasthope05 yeah I think your right. I’m going with Justin’s 20g, at least that way I know 100% that it will be ready to go.
I’m thinking I can just weld up that adapter to the turbine housing to prevent leaks.
The help is much appreciated fellas.
Yeah, not a problem. Keep in mind the adapter will lower the turbo down an inch or so, so your exhaust may not line up 100% like it did without one.
I think you should just grab a cheaper cast t3 manifold, you can usually find a turbonetics or treadstone, or a comparable one for like 100-150 in classifieds and you won't have to worry about anything leaking at all. I sold my black ceramic coated/wrapped treadstone for 120 on here a while back. So they're around
Just food for thought before you weld.
