your doing great !! ...i have the same car ...actually 2 of them and and one is stripped down and am doing the front end with the poly bushing /blast and repaint also ...keep up the posting and the good work !!Man time flies, Can't believe it has been almost a year since I last updated this. Haven't done much to the car, but plan to today after work. I finally found a good tool to strip off the undercoating easily. http://www.eastwood.com/eastwood-pneumatic-rotary-removal-tool.html. I picked up a slightly used one on E-bay for $200. Here's a small area I tested, found the medium wire wheel worked the best.
