NWHTanK's Eclipse GST (AWD swap)
Well I managed to blow up the 16g. So time for a rebuild and turbo upgrades
A tod6 housing with a three inch inlet and anti surge. Down firing
A billet 6+6 extended tip compressor wheel.
Still using the 080 fp hot side housing.
And a diffrent waste gate actuator.[DOUBLEPOST=1410302011][/DOUBLEPOST]Before the turbo went South.
Why did you change the interior back it was BA before?!
When i got the car it was black with the red seats and some white here and thier. Well were it was scratched was tan underneath. So someone did a mega spray bomb inside. All i did was bring it back cleaner with no spray bomb treatment.
When i was looking for a 2g I couldnt find a gsx that I liked and setteld on this gst for the main reason that it was clean and low millage 60k something . It just needed to be put back together. Now prior to me getting this car i had aquired alot of awd goodies some of which i used and some that stayed in storage. So when the motor spun i decided to put together a new build plan and transform the car yet again to build my dream car .
Parts that i have and adding to the build.
Built awd 5 speed trans stage 3 tre with locker
Dss front axels
Dss rear axels
Dss alum drive shaft
Wilwood brakes front and rear, road race setup with e brake, 6 piston front 4 piston rears.
Lsd rear diff
Alum front subframe mounts
Rear subframe with poly mounts and poly diff mounts,
Poly rear suspension mounts
ST 3g rear sway bar custom install
Whiteline rear endlinks
Megan rear control arms
New rear wheel bearings
New awd parking brake cables
Spare tire floor delete
Rm front sway bar with whiteline endlinks
The front suspension was rebuilt the first time with new oem parts along with wheel bearings.
Koni coilovers front and back.
450 fuel pump, 8 an feed 6 return
Jmf intake
Fp ball bearing black
Another 7bolt head , ported and polished. Both egr ports welded. New valves, behive springs, seals and guides. New lifters, new Comp 272 cams, fidenza cam gear. New valve cover
6bolt block and crank.
Eagle rods
Fluid dampner
New oil pump with stub shaft
Balance shaft delete
A/C delete
Power stearing delete
AddingElectric power stearing , collume is built.
Quik realise stearing wheel
Carbon hatch
Tubular north south bar
South bend clutch dont remember the specs
2gb talon front and rear bumpers
Talon high rise
Steaks
2ga head lights
Black front talon bumper badge, new
Hurst shift knob with micro switch, its for the stearing.
Innovative guages, boost,wideband,oil press and temp, coolant temp and volts, and fuel pressure.
External oil cooler
New water pump
Girdle
Things still to buy or have built
70mm tb
Way bigger injectors (e85)
6 bolt awd flywheel
Tcase , need built
6bolt short block. Have not decide still. 2.0 or 2.3 if going 2.3 then crank and 280 cams. Then the pistons
Ss manifold ? Curently have fp.
Oil filter housing
Billet mains
Gaskets, arp bolts.
Body and paint (staying northstar but going panda)
The wish list
Carbon fiber doors
Tubular front and rear subframes
Carbon fiber airbag delete
Carbon fiber sunroof
Black 17x9 45 Rfp1
255/45/17
Dream list , only becuase its not avail yet.
Light wieght knuckles front and rear along with front lca'
Thier you go. Hopfully this will give you a idea were the next stage of this build going.
Ok with car gutted of most of it mech items the time for the rebuild has begun. Now following the awd swap threads on tuners the drive shaft hanger , only one needed with dss drive shaft needed. Gas tank mounts and the subframe mounts are all done.
The rear awd items have been blasted powder coated or painted. New
St 3g rear sway bar, some megan rear arms, evo white line endlinks. Im mounting the endlinks to the knukles. The reason im using the 3g bar , its a little stiffer and i am making a custom rear exhuast. To route the exhuast the way I need I will have to have 4 inches or more of wiggle room between the sway bar and rear diff. Also with all this mock up it will allow me to change the jig setup for the sway bar location.
Exhuast routing, this is rough fit , being held up with bungi cords. I also plan on making a rear diffusor that will hopfully draft air out of the rear wheel arches. Also not the rear talon conversion.
