Eduardo Sanchez
- 0
- May 26, 2015
Modesto,
California
Looking to see what's the easiest way to do the job. I'll be changing flywheel and clutch while I'm at it. Is it easier to pull out the engine and transmission together or does the transmission need to be unbolted to pull the engine out. I'm getting apr flywheel bolts and a stage three endurance clutch from southbend. As for flywheel I'll be running th act 11 pound flywheel. Any other recommendations while I'm getting into this swap
