livedsm4g63
- 1,214
- 151
- Mar 1, 2008
Auburn Hills,
Michigan
Its time to build another 1G AWD N/A!!
As one knows, N/A's dont produce a lot of power..Itll prolly stay that way. This car is going to made with reliability in mind. For now we will start with the basics. Recently I bought a 1990 Plymouth Laser RS from an old guy in my area. Car has 82,000 miles on the clock. Yes 82,000 miles. It is also equipped with a 2.0 4G63 non turbo motor. Mind you, this beast has a 9:1 compression ratio. Little better then the turbo'd version, with a 7.8:1 ratio. Right now my goal is to fix up this fwd pos and drive it around. Im currently looking for a 1g AWD shell I can place this motor into. In time, Im sure I will find one.
Here is the fwd pos in my garage the night I bought her.
First day I thought it would be great to replace the valve cover gasket.
This reminds you, we are working with old warn out cars... Haha, spark plug wire were dry rotted.
This is how the front end looked before I started. Check out the driver side bumper support frame.
Chain meet dsm.
After that I heated up the frame and was able to pull down the support. This is what I came up with.
I did run into an issue though. The frame wouldnt budge after this. Didnt matter how much heat I gave it, it was almost stuck in place. So I gave up for the night. Before I left I decided to mock up the bumper and realized that the driver side bumper shock will have to be removed. This is due to the fact that, now there is no room for it to fit in the so called "frame". My plan is to drill the shock to release pressure, then cut the bumper shock off. Once this is done, the bumper should fit on without a problem. If this happens to fail, my mig welder should be up and running tonight too.
Chain meet dsm.
