828DSMs
- 42
- 10
- Jan 24, 2014
Conover,
North_Carolina
Did you set it all up in the ECU inputs tab?
You don't have the PC side assigned. In the chart at the top, Pin Assignments for Data logging, set the pins to the appropriate sensor.
Yes sir
