ECMlink ECU can't find MAP sensor?
828DSMs
42
10
Jan 24, 2014
Conover, North_Carolina
Like the title states, I just installed ECMLink v3 with an Omni 4 bar MAP and GM IAT sensor. I bought the ECMLink plug and play harness but when I do a capture it always says it cannot find the MAP sensor.
Did you set it all up in the ECU inputs tab? Post a log so we can see your settings will help figure it out.
You don't have the PC side assigned. In the chart at the top, Pin Assignments for Data logging, set the pins to the appropriate sensor.
This. ^^^^^^
You forgot to assign the sensors to the ecu input. Is this on a 1g or 2g?
If it's the one in your avatar then u would have to select the mdp or baro ecu input pin and select the appropriate sensor.
