2G Bent valves, slapped pistons, need your opinion wisemen.
jimsgsx
803
95
Oct 21, 2013
toppenish, Washington
Had a pulley fail, shredded my timing belt on saturday. I took off the head and all my intake valves were bent. I have never taken a dsm engine completely apart and need to know the damage and any other advice offered. What a crappy weekend! Was just cruisin going 50 when it happened. Thanks in advance.
The damage can vary greatly. If the valves contacted the piston, you could be looking at bent valves, cracked guides and possibly some seat damage. As for the bottom end, check the pistons and cylinder walls for obvious damage.
Yea i am rebuilding the whole head, i just wanted an opinion on where the valves hit the pistons. Thanks though. How they look? From what you can see anyways.
I've seen a lot worse. Those should clean up fine. The OEM cast pistons are pretty resilient.
I'd recommend getting the block deck all cleaned, to include removing all the excess carbon from the piston tops like so:
Dang how did you get them so clean? What did you do? And thanks for your input. Much appreciated.
After looking at your pistons, i realize you are correct. Mine are still good thank god. Lifted my spirits up a little. Ive never worked on a dsm engine or took one apart before so i just flat out didn't know if the pistons were bad or ? Thank you sir.
A brush and diesel fuel will work. You need to drop the oil pan to ensure anything that gets past the rings doesn't end up in the pan. This is a "motor out of the car" kind of job.
You want to take care that little to no crap falls down between the piston and piston wall. Put the piston at TDC and take your time.
Thanks.
